When I install the subwoofer do I remove the carpet?
get a old bike tube and cut it to a strip. then put the strip on top of the carpet and then screw it down real good. thats what i do and they have bin ok.
a good way to test it, is fill the box with water, then mount the woofer and see if the water leaks out where the woofer meets the carpet , if it doesnt, take the woofer back out , drain the water, and remount the woofer with no worries //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
whatever makes the best seal, if the holes a bit big carpets good, if the holes tight carpet will be in the way, use your best thinking //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
//content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif:laugh://content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif:laugh:
I do this with all my boxes, never fails //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
make sure you let the water sit in the box for a while to make sure the wood absorbs it for best results
lol awesome advice. I think I like the bike tubing method the best as it seems i'm allergic to water now haha.
Pull the head unit out, and at the harness use a test light to check 12v, ground, and Accessory. If all three are good, you have probably...
That blue wire with the "remote control" sticker on it: It's NOT a remote control wire. Its a remote... control wire. Its a switch that...
problem was the LOC burnt out when I had touched cables. got a new LOC and now all is working. have to get the gain right, lights flickering with...
Storage is actually pretty big ( but not big enough for an enclosure that's mounted on the door because it closes in an angle believe it or not...
15
dakayus
dakayus
LA
TurdFergueson2
Dan Medina
    Jun 17, 2024
    Jun 15, 2024
