whats wrong with this enclosure???
heres the email. notice i said id like around, but after that i said let me know what will work best. he is the designer not me, so if something else would work better like i asked why would he send what i suggested? he said he can work somthing up , meaning he will design it correct ? he had no discussion with me on this design just here ya go.
Ya i can work somthing up... i have a standard fee of $20 for design/plans my paypal is mobeious@hotmail.com
Date: Mon, 13 Apr 2009 15:29:01 -0700
Subject: digital designs t1510 box plans
To: mobeious@hotmail.com
hi i am looking for some plans for a t1510 the new shallow 1500 5" deep off a dd m1a at 2ohms so around 600 watts . its for a chevy silverado standard cab. i have 14.5" tall x 4" / 8.5" angle x up to 56" long i would like around a 1.5 at 38hz maybe 24 square inches of port . sub on pass side port out driver side. let me know what you think will work best thanks
Rediscover Hotmail®: Now available on your iPhone or BlackBerry Check it out. ReplyReply AllMove...amp scamebayenclosurespicuncle gary
no box thats actually tuned close to properly and close to the right airspace is not going to play a decent of amount of bass.
Somethings not right....with whatever port placement, doesn't matter, the sub should not flail around like it's playing free air because the port should control movement at least a decent amount.
Like said, take a vid of the box playing. There is NOTHING wrong with Mobeous's design. Its based off the standards of a proven truck box. Just seems like user error.....no decent designed box has problems like your describing. And it is a decent box design.
Please tell me that you had your driver side door closed when testing out this box??
x2 I usually port to the passenger side but I don't see much problem with the design at all.
Here is a design very similar to that one and it works REAL well for what it is. I call BS on the complaints as there is no way it makes NO sound, even the sub in no box would make some bass...This one shakes the shi* out of the Silverado its in with a single FI Q 12 and the port is almost identical in design/function. I bet the wiring is wrong or something in the install.....
Just my $.02
dd m1a. theres not a **** thing wrong with the system. i took my brothers hdc3 in 2 cubes threw it up on the passenger seat hooked it up and the system plays flawless. the sub has been tested in another enclosure and was also tested by dd it plays fine as well.
so you just took another sub and box and tested your amp out...that did a lot //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
Have you not checked to makes sure your sub is not wired wrong? What "tests" are you doing?
burzendowski
burzendowski
CA.COM
406er
BP1Fanatic
BP1Fanatic
