whats wrong with this enclosure???
have you tried another sub in the box you built?
i do not have another shallow 10 to test in this enclosure , this enclosure only accepts a 5" deep 10 cant just throw anything in there. i used another sub and enclosure to test out my overall system to make sure it was not part of the problem. system check everything is good. yes ive checked wiring from amp to but its all correct. ran a dmm on sub its wired for 2 ohms . ive checked voltage at amp , amps getting a consistant 13.5 + volts while playing. the sub has been played by dd in a spec 1.5 40hz enclosure and they said there is nothing wrong with the sub. they say enclosure issue.
heres my thread over at soundpressure. theres vids and all my testing there too.
http://forum.soundpressure.com/showthread.php?t=8390
shit if someone can fiqure out whats wrong here ill pay them 20 bux!
There might not be enough room for the sub venting behind the pole... I'm not familiar with the sub but it's possible.
Also the design is fine, what are you idiots talking about, how about a port on a back wall in a box, same ISH, there's not a fcking dead spot.
Somewhere, somehow, something's wrong.
There's no reason that box should be causing the issue you're having. It looks to be fairly well designed.
Either someone lied to you about your woofer being faulty or something is completely wrong in the audio. I'm not sure and I'm sorry I cannot help you. I do not, however, think it's the box by looking at things.
Ya'll are just idiots. That is a fine designed box, you are just a retard.
Call DD, and tell em that they are stupid, either the woofer is bad, or aliens are attempting to probe your rear door.
ON the other hand, I bet you just got broke and need that 20 back to pay your water bill. So, you call out an experienced designer on this public forum and try to clown on him? That is a very workable box, dumbass. I have one 99% exactly the same in my pickup. With a real sub, a Memphis PR-10, not some of that DD trash.
Eat shit and die slow, ***.
//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif:confused: you must have rode the short bus to school.
well i have a design coming from pwk designs. i also have vids of the mobieous enclosure , i will make a vid of the pwk design and compare the two. we will see the results soon.
i was all agreeing with you until you called DD trash. Go die.
port is acting like a hole in the box. Its not a correct port
If the port wouldve been along the back wall and taller, or actually if it was a correct port, the location wouldve worked.
a port is a hole in the box //content.invisioncic.com/y282845/emoticons/idea.gif.5acb6a39a9b92425414c316dda202bad.gif
burzendowski
burzendowski
CA.COM
406er
