whats wrong with this enclosure???
I would have designed it to where the sub was all the way to the right, and over top the port wall. You want to design boxes to where you can get the most amount of usable space. In his case, the sub is right next to the port opening and the area above the port is just dead space.
indeed. bad design, imo.
OP should seal up that cutout and mount the sub on above the port. Add spacers if it doesn't fit.
The area above the port IS NOT DEAD SPACE, explain your reasoning, you know using science, that this volume of air is magically isolated from the rest of the enclosure volume.
The sub is right next to the internal port opening which = bad design.
I did one like that in a std cab truck and didn't have any issues.
Then put the port on top sub on the bottom I would assume. If not possible then I guess you would have to make a larger box or use smaller drivers.
This t1510 sounds great n a .5 sealed enclosure. Can't wait to hear it ported.
burzendowski
burzendowski
CA.COM
406er
