Whats wrong with subwoofer?
ed_rob
23
ATL
I just installed my id12v3.2 into this amp http://www.partsexpress.com/pe/pshowdetl.cfm?&PartNumber=263-938&DID=7 wired in series and this subs is not thumping or playing to its potential. I had circuit city installed it for me and they say its the amp not putting much power to the subs and that i needed a bigger amp to feed this subwoofer. Is this true because my amp is rated at 250watts X1 at 4ohm and my sub is a dual 2 ohm wired in series to get 4ohm load. Why is the sub not hitting. It hits but seems like it need more power to it. Is it my amp not giving enough watts to the sub.
They set it a lpf. What if i set it at hpf what happens?
Then you decrease the bass even more //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Is there a subsonic filter on that amp?
Also, try raising the lowpass filter frequency some. Try 60-80hz.
ed_rob
ed_rob
ATL
Decado
