BoominBeast
Banned
EXP. ED
Just some help facts for noobs and whom ever is interested.
spectrum:
30hz-1 khz (low frequency)
30hz-5khz ( low to mid freq.)
150hz-5khz(mid freq.)
700hz-10khz( upper mid/treble)
1-20khz( high freq.)
A balance in the spectrum is vital for a musical system. its NOT just SUBS(LF) extension
Battle of the cones:
An extreme case of a wide angle cone would be a flat disc my peeps. If light and thin, it wil possess very little ridigity. Due to that the sub will enter breakup at Lower frequencies.
Having a rigid flat diaphragm. the axial stiffness will increase and the frequency response rises or becomes higher, with irregularity may i add.
SQUARE..cough..kicker.cough
I think philips in holland was the company that figured out what was up with the straight sided cones. Square cones produce waves with an arc the is much shorter than those equivilent frequencies in the air, this has less effect on the output than resonace freq. So the result is phase cancellation effect with irregularities in the axial pressure response and polar distribution.
I would also like to mention the many materials for the diaphragm
honeycomb aluminum, aluminum, iron, plastic, bextrene, Polypropylene, even boron.( DO you know whats in your SUB)
Just make sure you know what you are buying. Little things make a big difference
Rice and Kellog where the one who invented the paper cone, stil used today with modification. A good place to start.
spectrum:
