whats a good set of horns
  • 5
you could try some h ome audio drivers like eminence etc most important part is the horn body. and where your gonna install them. with the ID horns they go under the dash as far back as far out as possible. it'll bring your staging and imaging up above teh dash and **** close to center.
ok cool thanks, yeah i was going to put them under the dash my buddy had a pair of ID's and we put them in my car to see if they would work and they did, just cant get my rainbows loud enough with out the protection cutting them down and its starting to piss me off haha
what processing would i need? and they have something that if the tweeters get to much power it will take some of that power away by lighting up a bulb with the extra power and after it does that for a while it just like cuts the power off to the tweeters i guess, i dont think its the amp being underpowered due to that
you don't need ALOT of processing but a lil helps i was running horns off my old Eclipse Cd7100 and the built in xover was plenty. you want at least a xover of 1khz at 18db to 24db for the horns alone. then for the mids i'd go 80 up to 1khz
I don't think this is ideal, but let's assume you can easily mount all the tweeters. That installing them is going to be really simple, and...
13
In this Bidenconomy it is worth around $13,634. And a loaf of bread.
I think your front stage is spot on. If your DSP has a dongle that connects to your phone, then you are getting the full clear signal. No need to...
22
You could run that sub on a 4 channel amp and have 2 channels left for amping front speakers. I just put a small system in my brothers car with a...
16
tyoung87
tyoung87
NC
HeatSeeker
    Jun 15, 2024
    Jun 15, 2024
