What would too small of a box sound like?
JettaGLI
PDX
I just got 2 JL 12w6v2's and I put them in my fiberglassed enclosure. I set the gain with a volt meter per JLs instructions.
They sound like ****. I calculated it out, and, I need to have 20 gallons of water fit in there for it to be the "right" size of 1.25 CF.
I really don't want to have to dump and empty 20 gallons of water around all the electrical.
What would a box that is too small sound like?
WOuld turning the gains down help compensate for too small of a box?
dump a shitload of more power into them.
I have a 1 500/1 running each sub. That should be plenty.
THat is the problem, they don't have the low, deep sound. The w3v2's did though and they both require the same box size. Do you think I am beyond polyfill?
Any other good ways to measure a box volume besides water?
Inverting would only give me .2 cubic feet of space.
Why would I port? Wouldn't the box need to be bigger then?
Sub in too small of a box would have limited low end and be very exaggerated and sloppy.
check is in the mail. small box=sloppy?? i guess i will never get it? i thOUGHT small sealed boxes were nice n tight n accurate??? i believe you squeak but the plot thickens!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!//content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
A too-high Qtc will sound like ass.
The plot hardly "thickens". This is a fact.
Group delay, transient response, and frequency response all suffer badly once you go too far above a 0.707 Qtc.
Too small of box = very high Qtc = ringing and overhang, poor frequency response, poor low end extension, etc = sloppy and inaccurate
//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Most people perceive small boxes as "tight and accurate" because of the hump in response in the upper bass/lower midbass. And, if the Qtc is in check, there's nothing wrong with a "small" box. It's the "too small of a box" where the problems would become more apparent.
Thanks for all the help. I did the packing peanuts thing and have a box volume (with speaker displacement) of 2.44. So, I added 32 oz of poly fill. The subs call for 2.5 CF for 2 subs.
That wasn't the real problem though. I realized when putting the subs back in, that one of them was not sitting flush with the baffle, the box was originally built for 12w3v2's, so I used some super thich weather striping. The gap was about 1/16 of an inch.
VIOLA, super sounding bass!
2 500/1 each powering a 12w6v2, volt matched
1 300/4 powering vr comps up front, and vr co ax in the rear.
Thanks for all your help!
This is my thought as well. Would be a much better box volume if you could buy the 12" version of those subs.
The one and only mtx amp I've run was like that (it was black with the fake chrome platistic badging back in '01 I think) the first time I made a...
41
4K
You need something more like a pro audio woofer. You want a really light Mms with a lower Fs. Idk how much loudness vs range you want, but a...
14
16.6 is way too high. That will destroy an AGM battery. What alternator brand did you use? Sounds like a voltage regulator issue. Are you...
JettaGLI
JettaGLI
PDX
JettaGLI
