What will I need for my install?
EzekialPhoenix
ok, so you have an amp and and 2 subs. What else do you have? An aftermarket radio? Are you running any other pieces of stereo equipment, or just the subs and amp. If you are going to run an amp and subs off of a factory radio, rather than an aftermarket head unit, you will need different wires.
Purchase a 2 channel 4awg wiring kit from any number of places. that should have everything you need except maybe speaker wire. It should have power wire, ground wire, rca cables, remote wire, a battery terminal, fuse holder and fuse(s) and maybe some cable ties if they were feeling generous when they put the kit together. Make sure you fuse the power wire within a foot from the battery. that way if the sh*t hits the fan, you won't fry your amp and set your car on fire. Other than that, make sure you find, a good, secure, paint-free spot on the chassis to ground. Other than that, you should be good. Happy bumping.
Sorry buddy for leaving you hanging today. Had to run out quick, had an emergency. FREE PLAN.
CUTSHEET
Best I could do with your Diminsions. Cramped space in the trunk of a cavilier.
3.7 cubes @ 34.603 and some change Hz 43.5sq in. of port.
EzekialPhoenix
EzekialPhoenix
Minneapolis, MN
Chevyaudio
AJ (ACE)
    Jun 28, 2026
