what to power 2 xtant x 12's
  • Thread starter Unregistered
  • Start date
  • Replies 2
  • Views 934
  • 1
U
Unregistered
Guest
can any body recommend an amp to push 2 xtant 12's, bought em brand new for 99 bucks each, and my little mtx 75x2 aint doin a damm thing for em. their hungry little buggers. i was thinking the mtx thunder 81000d, found it for 379.00, just wondering if anything else would work good. oh yeah their 2 ohms.
yhanks
Those Xtant's are gonna slam! I've got a pair w/ a Kenwood excelon 401M pushin' em. Not many subs I've heard can hold up to em. The mtx amp your talkin bout puts out a whole lotta wattage... over 500 per channel. Plus the fact that those X series are 2 ohm subs... the amp is gonna see a really low ohm load. Its probably gonna be puttin out like over 550 to 600 watts per channel. The rms on the X series is 500 so be careful when adjusting the gain on the amp if you decide to use it. Also, make sure to use the subs in a 1 cubic foot box... any bigger will put too much excursion on the subs and lower the wattage handling.... especially if your gonna be using that amp. Good luck though... you're gonna love those subs!
Yes I agree you are going to love those subs. I had one 10" about a year ago and they it was very nice. However let me warn you now they are mega power hungry. My 250.2 Fosgate wasnt even enough.
Who had that Badazzed Astro Van?? I remember going to Austin seeing that ride. That thing made Earth pavement move about 50 ft before I got close...
566
Run the biggest AGM you can under the hood, the parallel runs to one of these - should be everything you need and then some...
744
What amplifier(s) are you using? What speakers? Is this your main battery or is it a 2nd battery? If it is a 2nd, how are you wired up? What if...
567
Guest
Nolesman
