What subwoofer to use with this enclosure?
Wow, thanks for all the info, Yes i will be running this off the stock head unit, its a brand new challenger with a 8.4" uconnect infotainment with bluetooth,nav all that stuff so anything aftermarket does not exist nor do i want to change it. Im going to use a audio control lc2i LOC on the factory sub output from the factory amp. Unless you guys have a more recommended option?
You going to Sanford next weekend?
Yep. Don't have anything setup myself, will be traveling with a friend. Just setup his car with 2 SA-12's and a rub1600. The box is some garbage he got for free but it does surprisingly well for what it is.
You competing this time around? Last time I saw you in lewiston you had the wall right?
Same setup here. Depending how much money and motivation I have late summer I may scrap the back seats and bring it up to the B pillar but I'm still on the fence about that.
Just gotta commit to it and make it happen. No regrets, no looking back.
It'll work. So you have to have an amp under 10" in length? The IA is bigger, but worth it. That US Acoustics should be good, too.
well i might be able to make that amp work. i will go out and take measurements later, im trying to keep this all minimal in size, keeping everything clean and not taking up my trunk space is important. keep in mind im not looking for some competition grade SPL madness, i just need some good clean bass with a kick from the rear.
DD M1 is at 13 inches. I came from large amps but this little one puts a smile on my face.
Those things work well, but def pricey. If you do go the DD route, you'll need to make sure you buy from an authorized dealer and need to talk them down to like $400 for that amp. If that won't work, pretty much anything at SSaudio.com is a good bet.
And yes, you should spend every last penny of that $800.
About $450. Same as a SCV-1500 shipped.
brewmastr
brewmastr
Portland, OR
fly_marlin
