have fun finding them and more power than a w7. Probably 1000-1500 is sufficient. Anyway, if I wanted 4 subs that are equivalent to a w7, this would be my choice.
http://www.diycable.com/main/product_info.php?products_id=661
They come in 4 packs at 150 a driver if bought in that quantity. It uses the same tech xbl^2 that you get from the xxx and cost less than you'd pay for a used xxx. Excursion is basically the same and they don't require nearly as much power. I graphed a 12w7 and a shiva x in the box you described using winisd. the w7 had slight edge below 40hz, the shiva did better from 40+. All in all pretty identical, better group delay with the shivas though, so sq might be better. This is mainly because the shivas want a bigger box, I'd stuff it with polyfll, odds are that'd fix it.
