what sub or subs do i need
well first of all welcome. You have A LOT to learn. If you want to hit 150 deeeeeeeeeeebeeeeeeeeeeezzzzzz you have to know how to build a very good enclosure. Just do some checkin in the subwoofer forums to see which subs are loudest in certain applications. Then make a decision.
what kind of car? List the model number of the amp, how much trunk space are you willing to give up, how much do you have? There is lots of questions to be answered and asked.
01 pontiac grand am. the amp is a digtal audio dhc1604. but when i had the audio bahn immortal 15" i had the box in the back seat from door to door and i would give up all the space i can
Specifications
Dimensions 11.5 x 24.5 x 2.5
THD at Rated Power 0.020
Rated Power at Lowest ohm 2400 x 1 @ 1 ohm
Power Rating into 4 ohms 300 x 2
S/N Ratio 100.0
Stereo Separation (dB) 60
specs on your amp lets say it does 1800 true watts are 1ohm mono. First of all you need to do the big 3 under your hood. Secondly I would prob add a second battery. that gets the electrical upgraded enough to run the amp. I would most like go with 2 12's of a higher end brand. RE, FI, DD, amonst others. Port your box and make sure your friend knows what he is doin makin the box.
all_state_34
all_state_34
hope, AR
Rich00
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
