What size wire?
t4r505
I am getting an elemental designs nine.2x amp in the next couple of days. I am going to rewire my wire because I had 8 gauge before. What should I go with 2 gauge or 4 gauge? I know people always say just get the biggest you can in case you want to upgrade but this might be a stupid question but will the 2 gauge fit into the terminal on the nine.2x? Also it is probably going to be like around 15 or so feet of power wire.
Also what size speaker wire should I use?
Just for reference the amp is underrated bridged at 600W @ 4 ohms and that is what I am going to wire it as.
If you did pick up the bigger wire you could use a distro block to get the wire down to 4g. Either that or just trim the 0guage. That's what I did when I had to fit my flex wire into my old Cadence amp.
I ended up just getting 4 gauge to be on the safe side and the fact that I wanted to buy locally so it was cheaper. I will probably regret it later haha
t4r505
t4r505
New Mexico
t4r505
vegang
vegang
