What size sub could I install in a wheel well
  • 2
Wheel well is pretty expensive to maximize space. Figure a good hundred and a half in fiberglass plus the aggravation of working with fiberglass. More simply would be to create a wood box that fit down in there and just flush it off with the top side (which should be easy to measure).
Otherwise, get some foam peanuts and pour them into the well, then take a small cardboard box (of a known volume) and measure out the peanuts to get a rough idea of how many cubic feet you have to work with.
It is likely that single 10 or single 12" woofer would be the thing. I've seen some great examples of this for a stealth build and you can certainly get great sound out of most modern 10" woofers on 500-600W or less.
I would run a pair of 15s in an suv.. or run 4) 12s
24
I’ve never owned them but have heard a lot of crossfire products and like them a lot.
22
Could not tell you, but you may want to start by going to crutchfield and get a consensus on the 7 or so replacements they recommend. That average...
Absolutely. I am always learning and think it's probably impossible to stop learning. I appreciate the advice and don't doubt for a second the...
56
4K
funonahonda
funonahonda
Ohio
hispls
SPLBassJunkie
    May 21, 2024
    May 20, 2024
