what size isolater?
mecaspl151
i have 2 sundown 3000's running of 1 run of 4/0 wire each amp says 300 amp external fuse what size isolater will i need keep in mind i only have the 1 run from front to back
the reason i ask is becouse i have my mids and high amp wired to the front batt and the amps are pulling current from the front batt along with the back and when my front batt goes a littel low it cuts out the mids and highs and i have is bass the front speaker amp is a zapco
i didnt really understand your question because there is not one period in the 3 lines of shit you said. I will try though, you dont need an isolator, are you playing music off for long periods of time? How many batteries do you have? Unless you are playing music with the car off then you dont need an isolator. Do you have a h/o alt?
i have 2 hc 2400's no ho alty at this time but on long bass lines my volts drop and my front amp quits working at full tilt till i turn it down its a zapco amp and when the volts drop to say 11.8 to 12 volts the zapco will shutdown till the volts go bak up and it takes up to much time to put periods and stuff so sorry about that this is not school lol
mecaspl151
mecaspl151
sugervally
dave_damage
