What size fuse do I need?
seatown1two
Looking at photos, zed draconia II doesn't have any fuses on the outside, will be running front (100x2) for comps and rears (400x1) for sub... Was looking at wiring kits and one that I'm looking at comes with an anl fuse (100 amp). Will that be too high? Should I get a fuse closer to 50 or 60??
it would be safe to do a 60,in my opinion...if it blows go to the next size up..you can email/contact zed audio,to get the information
Current Consumption with Sine wave at 4 ohms: 42A
Average current Consumption with Music at 4 ohms: 8 to 15A
I'd think you could base it off that. I could be wrong.
or this
Fuse rating with 4 ohm load: 25A-30A depending on usage
Fuse rating with 2 ohm load: 30A -50A depending on usage
From Zeds website:
Specification DRACONIAContinuous Output Power into 2 ohm 200w x 4
Continuous Output Power into 4 ohm 100w x 4
Typical Output Power into 4 ohm per channel (1% THD) 130w x 4
Continuous Output Power 2 channels bridged into 4 ohm 400w x 2
Continuous Output Power 2 channels bridged into 8 ohm 200w x 2
Minimum Speaker Impedance 2 ohm per channel
Minimum Speaker Impedance in Bridge Mode (2 channels) 4 ohm
Power Response at any power into 4 ohms 10-60KHz -2dB
Frequency Response at rated power into 4 ohms 10Hz-30KHz -0.1dB
Input Voltage range for rated power into 4 ohms 0.26 to 8.0 volt
Input Impedance at 2KHz 47K ohm
Noise below rated output (30KHz limited) -98dB
Channel separation at 2KHz >80dB
Damping Factor at 20Hz with 4 ohms >80
Total Harmonic Distortion with 4 ohm 20Hz-20KHz
From 1 watt to rated power. Typically less than 0.05%
Intermodulation Distortion
Phase response at 20KHz Lagging 12 deg
Slew rate (volts per micro second)-In”Flat” mode 12
Low Pass Crossovers (24dB/octave) 55Hz to 4KHz
High Pass Crossovers (24dB/octave) 55Hz-4KHz
Sub Sonic Filter (24dB/octave) 11Hz to 48Hz
Equalization (Zero to +12dB variable control with constant Q) Boost @40Hz with constant Q
Line Outputs No
Protection - Short Circuit, DC, Thermal Yes
Power Source 10-14.5v DC Negative Ground
Current Consumption with Sine wave at 4 ohms 42A
Average current Consumption with Music at 4 ohms 8 to 15A
Idling Current
Fuse rating with 4 ohm load 25A-30A depending on usage
Fuse rating with 2 ohm load **** 30A -50A depending on usage
Size W x H (247mmx55mm/9.7”x2.1”) x L 275mm/10.82” Excludes connectors
Shipping Weight (Kg/Lbs) 5.9/13
http://www.zedaudiocorp.com/pdfs/ZedManual-2011.pdf
been doing a little more reading.... So the fuse at the battery would be to protect the wire from the fuse to the amp right? If so, would a 100 amp fuse suffice for a 4 awg wire??
seatown1two
seatown1two
Edmonds, WA
Rich B
AJ (ACE)
    Jun 28, 2026
