Which is better?!
Quick
I keep seeing top 10's and the kenwood KAC 7204 is always several spots above my kicker zx250.2! But I doesn't hit as hard as m kicker I don't feel like! Is this amp really that much better? Has higher rms and everything but idk! Help plz. I have both amps and I wanna know which is better to use!
Kenwood specs:
CEA Rated: 170W X 2 (1.0% THD+N) (4Ohm/2Ch)
• 250 Watts x 2 (2 ohm)/500 Watts x 1 (4 Ohm Bridged)
• High Quality Speaker Level Input
• Blue Illumination
• High-pass (12 dB per octave) and low-pass (24 dB per octave) filters variable from 50 to 200 Hz
• Variable Bass Boost Control(0-18 dB at 40 Hz)
• Cooling Fan
• MOSFET power supply
• Speaker-level inputs with signal sensing turn-on
• Preamp-level inputs and outputs
• Fuse rating: 40A x 1
Kicker specs:
85 watts RMS x 2 at 4 ohms
125 watts RMS x 2 at 2 ohms
250 watts RMS x 1 in bridged mode
unregulated Class A/B power supply offers a significant increase in power at 2 ohms
stereo or bridged mono output
4-ohm stable in bridged mode
Tri-Way capable
3-way protection circuitry
speaker- and preamp-level inputs
bass boost (0-18 dB) centered at 40 Hz
variable high-/low-pass crossover (50-200 Hz, 12 dB per octave)
frequency response 20-20,000 Hz
preamp outputs (pass full-range signal to another amp)
It ain't all about rms...different amps are better with different subs there's a lot more to look at
So I have learned, but i was just giving a example. Still, shouldn't it be better if it's rated better and is more powerful?
No because Kenwood doesn't compare to kicker amp wise...kicker has a more true rating for amplifiers and is much better in general....its like saying why doesn't my V8 engine SUV go faster than my buddy's V8 engine challenge uk what I mean?
The Kenwood wouldn't be CEA rated if it didn't output rated power, stop talking out your ass.
Quick
Quick
Texas
bubbagumper6
Mike Mccabe
