What size battery for Two AB XFL 15's.
Pyrofan
Ga
Running two XFL 15's off of 3000 or 4000 watts. ( havent got an amp yet). What size battery do i need. Like to pick on up local. I was told 100 amp Deka but i got no idea what that means. Is that cranking? Total? Need help kinda soon.
i think the general rule of thumb is 55ah per 1000 watts so about 165-220 ahs.
Deka is rebadged as alot of diff brands ....do u have a sams club or oreilleys ??? And if he doesnt have a ho alt and a good battery umder the hood a single battery isnt gona work...the big duracell or super start are around 170 each
His alt is good. MyLowes said the alt is fine. I do have a sams and orilleys close by
Not sure where to find one.
O'Reiley's auto parts' premium AGM battery is built by Deka. Also consider the Sears Die Hard Platinum AGM style battery. High quality and very good warranty. AFAIK Sam's Club also has a "Duracel" brand AGM battery made by Deka. Get a couple 105 to 110AH size and you should be pretty good.
Naa man, they're talking about 100 AMP HOURS; It's a different kind of rating versus Cranking Amps / Cold Cranking Amps; At a Minimum, you will likely need (2) Kinetik KHC2400's, possibly even 3;
Pyrofan
Pyrofan
Ga
TrillGates2k6
