What should i seal the inside of my box with
I asked in another thread but noone replied so imma try again. What can i pick up from walmart that will seal the shit outta the inside of my box? Ive seen alot of people use some type of white silicone caulk stuff it looks like, what is that? I just need to know what to use so i dont mess up my first real box build. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I have a few things right now i could use, if any will work
Liquid Nails
Gorilla Glue
Titebond II
Elmers heavy duty wood filler
//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
i think sealing the inner joints is pointless if you use adequate glue for the joints from the start.
waste of time IMO
most of the time the glue beads over into the inside of the box anyways........
That's why you leave the box building to us, big boy.
And like I said in the last thread... put a nice bead of wood glue in the joint, then put mad dust in there, and compress... repeat if necessary.
He's right //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
the glue is a seal in itself between the two surfaces and unless you have poor cuts/joints, silicone is really unnecessary, but like said above, it doesn't hurt to take the extra precaution if you're worried about it, or just dont trust your gluing/jointing job
Not to mention, unless it's huge gaps, we're talkin about less than 10th's on a meter, and a very slight drop in tuning.
on my current box (the one built in my trunk), I have leakage out the ***. Effective tuning is about 4hz under calculated tuning and it's doing decent numbers for the equipment/install.
I Like Waffle
North Carolina
Cravingbass123
