What should i get, subs !!!
h2h0e
First ive got an apsm-2000 as amp here the spec :
900W @ 4 Ohm
1400W @ 2 Ohm
2000W @ 1 Ohm i know my amp dont do the rated power but lets say it does what it show -25 %
I listen to all kind of music (hip-hop,rap,rnb,rock,metal (sometime) and ive try ported and sealed box i like both
I like big kick bass and i like low bass too
Ive been looking for 2 x10 inch subs like : Pioneer Premier TS-W2502D2 , Alpine type-r Alpine SWR-10D2 or maybe sundown SD-2 10 ,
What you think should i buy considering i like kick bass and low bass at the same time ? (if you guys have other subs idea go ahead my budget is around 300 $ pair )
ty
and i think ill be running this amp to 2 ohm so i wont stress that amp so lets say i will get 1000 w rms
i cant post lol
---------- Post added at 06:30 PM ---------- Previous post was at 06:29 PM ----------
i cant post long thread
900W @ 4 Ohm
1400W @ 2 Ohm
2000W @ 1 Ohm i know my amp dont do the rated power but lets say it does what it show -25 % //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
ty
---------- Post added at 06:32 PM ---------- Previous post was at 06:32 PM ----------
there we go , and i think ill be running this amp to 2 ohm so i wont stress that amp so lets say i will get 1000 w rms
No , i mean im open mind :
Thats what i wrote up there : Ive been looking for 2 x10 inch subs like : Pioneer Premier TS-W2502D2 , Alpine type-r Alpine SWR-10D2 or maybe sundown SD-2 10 ,
So witch sub under 300$ will do the job for me ? I Am not an expert so thats why i want a good pair of 10 considering i like kick bass and loud bass ,so im asking you guys, and at the same time if you know a good 4gauge amp kit under 80$ witch i guess is ofc go ahead lol
Pay attention to what mylows said, and stop running around in circles. The ab xfl's or tnt's in a properly built ported will give you what you want, even a properly built sealed box would work, double 07 built a sealed box for my re se 10's and it pounds the lows. The response you get depends on the box and its design.
are you limiting to 10 inch due to your budget? ''cause for c2 audio 12" its only $200 for a pair of 12" shipped and they are very beefy subs and will be perfect running on those apsm 2000
Specifications:
12" Threatcon-2 Subwoofer
600 Watts RMS
Available in Dual 4 Ohm and Dual 2 Ohm
Dual 2 Ohm: Threatcon-2 12d2
Dual 4 Ohm: Threatcon-2 12d4
3" Copper 4 Layer Voice Coil
Double Stacked 160 oz Magnet
High Current Flat Woven Tinsel Leads
Dual Spider Pack
Dual Stitched Non Pressed Paper Cone-
with Mid Excursion Foam Surround
Enclosure Recommendations:
Sealed: 1.0 - 1.25 ft^3
Ported: 1.5 - 2.0 ft^3 @ 35hzSealed: 2.0 - 2.50 ft^3
Ported: 3.0 - 4.0 ft^3 @ 35hz
T/S Parameters:
FS: 36.7HZ
VAS: 40.9 DM3
QES: .44
QTS: .40
BL: 16.8
MMS: 167.7G
SENS: 91.5 DB
XMAX: 28 MM
Woofer Dimensions:
EXT DIA: 12.48"
CUT OUT DIA: 11.18"
MOUNT DEPTH: 5.82"
h2h0e
h2h0e
canada
h2h0e
