what kind of computer should i build?
LOL, why don't you suggest something to him then, instead of just saying go to tomshardware?
Exactly my thoughts //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Like I mentioned above, tomshardware is still decent and all, but nothing like it used to be years ago, in my opinion. A lot more cluttered now.
Intel's due to release their new socket this year as well as 8-core processors (might be balls expensive for an 8-core, but will make 6-cores a lot cheaper). The processors will also be 32nm instead of 45, and with the new socket/boards comes a new chipset obviously too, which will make more features for boards too. Possibly instead of only having 2 USB 3.0's and 2 Sata 6gbps ports on most boards they'll be all usb 3.0 and native sata 6gbps?
(Most boards use an extra marvell or intel controller to support the faster sata ports instead of it being native in the chipset, which from what I've read leads to finnicky raid support at times for the 2 sata 6gbps ports)
I appreciate it, I've only learned from mistakes in the past, learning hands-on is the way to go.
Word.
So now i'm looking at the 1155 and a sandy bridge..also not taking nearly the amount of pain medication i was on.. hence better retention and understanding.
I saw a deal on 8 gigs of Corsair XMS 1333 (2x4gig) for $47 after rebate and couldnt resist.. so that's all i have purchased so far. I saw the crucial c300 hit just over $200 but i waited thinking with g3 drives about to come out and ssd prices dropping i should wait.
I found the corsair case i still want for $119 a/r think i'll probably pick that up in a day or two..
I'm thinking a i7 2600K with ASUS P8P67 Deluxe ..
what you think of sandies bridges?
I go back and forth in my mind about if i should just buy everything i need all at once and pay the premium or piece it together on the cheaps.
I also really cant decide if the roughly $100 premium for a i7 is worth it or if i'd get by with a SB i5 just fine..
I built an i7-950 - mostly through newegg shocker sales
but lemme tell you this fker is FAST !
If your building today Sandy is the way to go,it was not out yet when I was building
i5 SB is as fast as my i7950 so you do not have to break the bank for spectacular speeds
I also built an AMD 955 2 weeks ago for a friend,not even in the same league as far as speed
goes.....
good luck
Ya man I mean if you've been using laptops for the last 6-7 years an I5 will be plenty fast for you, unless you had a beastmode 2-3 grand laptop lol
only extreme multi-taskers, photoshoppers, renderers, etc will really notice a difference in I5s and I7's, if you do get an I5 though just make sure you get the quad core and not a dual core I5
good thing i didnt jump on a p67 and a sandy bridge just yet..
Intel has halted shipments of its recently released Sandy Bridge Core Processors, after indentifying a design flaw which could lead to Serial-ATA (SATA) port failure over time.
The flaw, in the Cougar Point 6-series range of core-logic chipsets, which support the Sandy Bridge processor, will mean a recall of systems that have already shipped to end users, and a delay in shipment of new, rectified chipsets, until later this month, with full volume not expected to recover until April.
Intel says it will reduce revenue by $300m in the first quarter of 2011, and the total cost to repair and replace affected materials and systems in the market is estimated to be $700 million.
Hundreds of new models of PC that were expected to use the Sandy Bridge processors, will now be delayed.
Intel says that it had only been shipping the flawed chipsets since 9th January, and that "relatively few" customers. Systems running quad-core Core i5 or Core i7 processors will be affected.
I also decided not to order the corsair 600T case i was looking at when i saw this sexi beast they just announced at CES:
Quality Construction
The Obsidian Series 650D mid-tower case is manufactured with strong, stamped steel parts for increased rigidity, and coated in a black textured paint. The front panel features a beautiful black brushed aluminum faceplate to bring a subtle elegance to your next build.
Excellent Cooling
A large, black 200mm intake fan hides behind the front dust filter, quietly pushing vast amounts of air over your hard drives and video cards. The air is then exhausted by a second 200mm fan on top of the case, and a rear 120mm fan. The top fan can be replaced by dual 120mm or 140mm fans, and is pre-spaced for a dual radiator if you’re interested in watercooling. And all fans are controlled by a three-mode, four-channel fan controller should you want to make your own choice between noise and performance.
Award-Winning Features
The 650D is a member of the award-winning Obsidian Series of cases from Corsair. The Obsidian Series is more than just a name — it means real features that can benefit even the most experienced system builder.
Dual 200mm fans provide outstanding cooling for even the hottest components
Easily accessible dust filters make maintenance simple and hassle-free
Quick-release side panels make it easier than ever to upgrade your hardware
Integrated fan controller lets you quickly adjust cooling performance and noise levels
Four tool-free optical drive bays and up to six SSD-ready hard drive trays provide plenty of
expansion
CPU backplate cutout makes it easy to upgrade your CPU cooler
Brilliant cable routing system provides a way to keep your system neat and tidy
Adjustable drive cages can be removed and relocated to accommodate large video cards
Room for long power supplies gives you peace of mind for future upgrades
Maybe I'm tired but 2-3db of ps3-1600? If you mean 2-3gb you should save your money and not get an I7. No real point in getting an I7 IMO if you're only getting 2gb of memory.
That, and the case he picked out may be 300, but it comes with a solid 850 power supply so it's not purely the case.
i think i meant to type 2x2gb of ram. ill be getting 4gb total. didnt realized the case came with a psu.
faulkton
faulkton
neverland
faulkton
