what kind of computer should i build?
For what you want, you could get away with an AMD build, but your budget would allow an i5/i7 build.
i5/i7
Gigabyte/ASUS Motherboard
Corsair RAM (DDR3 (At least 4GB for the i5, and at least 6GB for the i7))
Corsair PSU/PC Power & Cooling (CMPSU-750TX is a good deal right now for a 750W, or the Silencer MKII by PPC which is what I'd prefer)
An Nvidia GTX465 or HD6850 (I'd prefer the 6850, more options with Built-in HDMI)
Crucial SSD (64GB C300 Sata 6Gbs, don't need much more for an SSD, just for OS which leaves about 35GB for main programs/games)
A few 1TB or 2TB drives for storage.
Case is pretty much just whatever you want. I prefer something that has great air flow, and can manage cables very well.
I just cant really decide, if should get a phenom 2 X6 1100T for about $275 or i7-950 for about $295. Just not sure if there would really be any noticeable difference in how i use my computer... and future potential.. cost isnt that different...
if i was going i7 i'll probably get 3x4GB of corsair ram... and they do make nice PSU too.
although i usually have gone Antec for case/psu in the past, it seem like antec has gone a little too 'fast and furious' with their case styles ... they used to be so much simpler, well constructed and functional.. a lot of the new ones just look gaudy tho ...
I know i want a modular psu this time... but i'm not sure if 500-650 watts will be enough or if i really need to be looking at like 750 and up... I just want a SSD, a few regular HDD, single graphics card, a couple optical drives, and enough reserve power to maybe do a little over clocking.
I think 128GB for a SSD drive might be the sweet spot for me, i think i might find 64gb a little limiting after a while.
The HD6850 is also a card i've been eyeing because it seems like a good value for what i want to spend... and should suffice for my needs... but not sure if that would be best choice with an I7 or not.
I've always had good luck with Asus or gigabyte in the past... so Asus is pretty much were i always start looking first.
What do you think of this??
79303196.jpg%20
I'm not sure about the 850 watt PSU... think i could get by with a 650?
What about the heat sink?
Mobo and Graphics picks?
ur electric bill? come on... overkill psu is not a problem unless u need to lower ur budget.
tomshardware.com
there are charts there for comparing what processor, what hard drive, etc. are better, or faster.
there are also builder marathons, that people come up with the best computer for X money.
here is their $1000 pc
System Builder Marathon, December 2010: $1000 PC : Let's Give Core i3 A Chance
here is their $2000 pc
System Builder Marathon, December 2010: $2000 PC : Luxurious Performance?
might give u ideas on what u should use or change
i personally go amd because u get more for the money. but i also use toms charts to compare whats best for my budget
lol i try
only other thing i can add, which goes against what the link i just showed u, is i dont like western digital anymore.
me and my dad both built pcs with them, ya they lasted a couple years, but both died on us.
im using seagate now and been a couple years no problems.
but could also check their hard drive list, they have stuff like boot times, so u can find the fastest stuff
I would never spend more on my case and PSU than on my graphics card. I am also a fan of Patriot memory, never had an issue with it, and it is less expensive than corsair.
The Intel "i" processors are great.
I think you should try and keep your budget low. When building computers it is always super easy to get excited and carried away from what you really need...
lol i try
you know in the last 10-12 years i've had problems with both maxtor and WD but never once with a seagate.
An i7 rig would be the fastest and they overclock like a dream. I have a i7 920 at 3.5 on air. Instead of wasting money on a ssd. Get a couple wd Black 640 or 750gb hds and run them in a raid 0 array. You can run a raid 10 on the back of the drives to ensure no data loss if one dies on you. I have a raid 0 with 4 750gb wd blacks and get high 500mb/s reads and 400mb/s writes. (the access times still can't keep up with the ssds tho)
I would never spend more on my case and PSU than on my graphics card. I am also a fan of Patriot memory, never had an issue with it, and it is less expensive than corsair.The Intel "i" processors are great.
I'm no hardcore gamer i just want to be able to play most new games on medium or high. It'd be pointless for me to buy a high priced multi card set up.
I also disagree on not getting a good case/psu because they outlast several mobo/gpu/cpu iterations.. A high quality case is not only designed and laid out well, but easy to work in and route cables for a clean look and excellent air flow. A quality case is just packed with features you never knew you needed so bad..... but now cant live without.
A good PSU also outlives plenty of systems and it seems like the minimum wattage the average computer requires just keeps going up. I figure its best to buy a PSU with some overhead for the inevitable increase in how much power a system takes.
i'd like to do a little OC'ing and requires a quality PSU with steady output. I've also just had good luck back in the day with corsair ram and overclocking.
$1k budget? Jesus if you arent gaming I can build you something noce for that price.
i want something nice!!
i dunno.. i wanted a SSD drive for quite a while now and they're really coming down in price. I'm thinking i'll stick with a 128gb ssd drive.
What HSF do you use to OC your i7??
While I agree people shouldn't spend insane amounts on cases and PSU's, it's also often understated the luxury of a good case.. The difference in cases can mean much better wiring and cooling. Personally I'd never treat a new (performance) computer to an off-brand PSU i've never heard of. An off-brand might be "rated" at 1k watts, but a good 850watt brand like cooler-master, antec, etc will almost always outlast them.
On that note, have you considered looking into a coolermaster case and PSU? Might be a little cheaper and still get good quality:
Newegg.com - COOLER MASTER Storm Scout SGC-2000-KKN1-GP Black Steel / Plastic ATX Mid Tower Computer Case
Im betting the crucial SSD will outlast most hard drives, older SSD's werent too reliable but the crucial SSD's are awesome, I've built a few builds for customers with them at the shop.
Patriot isn't "bad" memory but corsair is definitely better, my two favorite memory brands are kingston and corsair. More likely to run into compatability issues with other brands such as patriot, gskill, etc.
I agree with the others though.. Go intel with an I7, AMD may be cheaper but I7 will perform better and give you less problems when it comes to most of the boards. For instance, if you got an AMD 6 core you'd have to make sure the board ships 6 core ready and not "6 core compatable." A lot of people ordering 6 core boards found themselves with boards that had old bios releases and couldn't run the 6 core processors until they found a cheap sempron or other AMD processor to update the bios with..
Personally I've build a lot of I7/I5 builds and a lot of sick AMD builds, and I always spent less time getting the intels up and running and looked forward to building them more, and they showed the difference in benchmarks such as 3dmark too.
When it comes to seagate vs WD, as long as you go with one of the two you should be fine, any other offbrand is asking for trouble, I personally always go with WD though, 80% of the drive failures I see at my work are brands other than seagate or WD
I will say you picked a great board too //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Check out this heatsink: Newegg.com - COOLER MASTER Intel Core i7 compatible V8 RR-UV8-XBU1-GP 120mm Rifle CPU Cooler
I've used it in about 10 builds and it works great, cools well and looks good too. Overclocked both AMD and intel processors pretty well with it. Had the 6 core extreme I7 running at 4.2 stable on air with it (customer didnt want us to push it too hard so I didnt go any further)
My 2 cents is usually when I spend 1-2k or know someone spending that much on a computer, I usually like to make sure it's "futureproofed" for at least 4 years, meaning it has room to upgrade and can power said upgrades too.
Seagate is junk now... grab Western Digital or a Samsung hd. Better yet grab an Intel Solid state drive so you can open up everathing at once and then grab a big samsung 2tb hd or something for storage. Pair that with i5 intel and a decent asus mobo with 4gigs ddr3 and call it a day. There are cheap ATI vid cards with hdmi out for your viewing needs. If you need a case and a powersupply just check slickdeals or fatwallet for sales. Dont skimp on the powersupply. Seasonic 600watt should be plenty.
Cliffs: Get a dell... check fatwallet for sales every week.
EDIT: Seagate use to be great, but after they acquired maxtor, they went downhill and aren't that reliable now. Funny how good companies acquire crap and then fall to their level. Same thing happened to Mercedes for a few years after getting in bed with chrysler. Avoid those year chrys.. err mercedes too. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
faulkton
faulkton
neverland
faulkton
