what is the Ohms??????
  • 2
EVOECLIPSE
yes i am looking at buying 2 alpine Type R's. they are dvc 4ohms per voice coil. and i want to run them at 2 ohms. is this posible? i dont know the equation for the problem. i was thinking of using a alpine mrv500(mono amp) to power them. i was wondering if anyone could help?
thanks
your wiring options are 4connections of 4ohms,2@2ohms,2@8ohms,1@16ohms,1@4ohms,1@1ohm. So if your looking for a 2ohm connection with DVC 4ohm sub you would have 2 connections.
what do you mean by have two connections? i dont get it. so if i buy these subs i can wire them in for 2 ohms? how would i do this in series?
//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
you would have 2 connections for 2 channels of an AMP. YOU would put each speaker's coils in parrallel by wiring the positives & negitives togther then connect that to the amp.
so i wire 1 sub two each channel of a 2 channel amp? i think this is how you describe it. b/c i was wanting to run a mono amp, and with the setup you gave me i could not use a mono amp? say i connected the subs in series two a mono amp? what whould the ohms be?
Yeah, if you haven't bought em yet, then get a matching third sub. I would wire them to 1.3ohm, unless for some reason, you have some really...
Follow the wiring diagram for the final 1 ohm load for the 6.5s and the 1k amplifier...
Thank you for all your help and I'll let you know how it all turns out. I'm putting it n a kia optima. I hope that it sounds as good as i think it...
10
EVOECLIPSE
EVOECLIPSE
New Paris, OH
EVOECLIPSE
Decebal
    Jun 10, 2024
