What Is A Good Amp For...
looking now.. so if I run h.o. alt no need for second batt. ?
---------- Post added at 12:27 PM ---------- Previous post was at 12:26 PM ----------
yeah just realized that, so used to 1 ohm...
Depends on how large the alt is. The alt makes power, the battery should just be for reserves.
I didn't realize you were only going to be running only 2300w. I'm running a 2500w sub amp and about ~250w to my front stage on a 240a HO alt and AGM under the hood. I have almost no voltage drop except a moderate amount at idle.
my car kills agms, can't understand it, don't know why, but they all go bad in a month... stock batt. fine... think it has to do with the bullshit ecotec gassaver/voltage regulator
so 200+amps
If you plan on keeping the car a while go ahead and get a HO alt. if not, just stick another battery or two in the back and call it good. Your alt is a little small for that power level but not too bad.
---------- Post added at 11:37 AM ---------- Previous post was at 11:36 AM ----------
Invest in a good AGM battery charger/tender and put your car on the charger every now and then to top it off.
yeah, I had a power hungry zrx2000d at 1 Ohm and dropped into the 13vs, my car idles low at like .5
tried diehard plat., and two yellow tops all brand new and got killed within a month... they think the v. reg. don't charge high enough to keep them up so they just drain and die internally, so i went back to stock
I have had great luck with sams club agm batteries get the big group 27 for like 129 its a steal. deka made.
do your big 3.
amp //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Harman Audio - GTO24001
thank me later
big 3 done, nice amp just don't like only as up to 4ga inputs, I got oversize zero ga ran already
13's is actually not bad voltage drop, even mid 12's as long as it goes back up to high 13's, i use the harbor freight $20 charger, charges my car on the weekend, my alt is smaller than yours i have 2 35ah battery and running 3 amps
brz 1700.1d
RF 1000pxd
usacoustics 2080
and sometimes on big bass it drops to 12.3 but recovers quickly
basswiigee
basswiigee
MICHIGAN
naughtyca
michigan born
    May 14, 2026
michigan born
    May 14, 2026
