What happens if SSF is set inaccurately?
It will rip a hole in the atmosphere allowing solar radiation to bombard the earth causing an early rapture.
Your settings are fine.
i know they are probably fine but i just am curious as to what happens if i were to set it to say... 20 hz.. does that just allow my sub to accept anything over 20hz with no consequence or what?
It allows the sub to cool better when playing below tuning, if a sub isn't moving much then there will be no mechanichal force to cool the coils when they heat up and they eventually might fry.
If it's set to low when you go to do a demo for some one you will crank it and hear a funny clacking noise. You will turn it down and say what the hell was that. The guy watching will say crap dude, You are bottoming out your subs mang...
ok so what would be the diff if i set it to 20 hz as opposed to 30.. nothing? or is that not a good idea
If anything, the sub will cool better as it's unloading, as there's significantly more coil travel than when the cone is under control...what destroys the driver at that point is mechanical suspension damage, not thermal damage //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Then what am I thinking of when there is almost no cone travel?
Edit: Not arguing, would just like to know for future referance.
Jakeeck
Jakeeck
Eutopia
PaulThompson229
