What gauge wire?
Thanks so much for your help guys/gals! Im so excited that I don't have to rewire my current setup //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif This is one of the best forums, if not the best forum for help I have been to so far //content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif//content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif
Thanks again,
-aek
Thanks again,
-aek
You are welcome.
I wouldnt say its the best.
If you get the right people helping you it can be very helpful
Ok... bad news, I just checked under the hook of my truck, and it's actually 10 gauge wire comming off of the battery to the amp. So... would I definetly have to change my wire now that its 10 gauge and not 8?
Uhmm, ya might wanna get the 4 ga.
Only time ive seen 10ga waws when i was removing it to put in something bigger //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
alright, thanks for the info guys //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif I'll be re-wiring it tuesday hopefully and get everything up and running to its full potential (right now I have the 2 RF running off of an old Jensen 100 x 2 amp (40 rms per channel, lol)
Ghetto style baby !
I was really supprised that the 40 watts rms per channel jensen actually puts out sound through the woofers //content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif Right now im following some "break-in" rules that crutchfield suggested that I follow. They said I should play the subs at a low volume for 20 hours total so they last longer and preform better. What is your input(s) on this? BS or good rule to follow?
One more question... since my amp is pretty low watts, and the subs rms range is 50-150, would it hurt the sub cranking it up pretty loud , or would it just most likely cause the amp to over heat?
aek
aek
KS
RandyJ
vegang
vegang
