What gauge for voice coils?
So 12 would be fine then? I have 8 gauge to run from my amp to the terminal, but the 8 is too big for the voice coils. I think the 10 I can get to fit, so I'll try that first, and if not, I'll just go with the 12. Just wanted to make sure that the 12 would be ok since it'd be going from 8 -> 12.
Now my only other question is should there be 1 wire run straight through to the other coil or should there be 2 wires, one into the first coil, then the other stacked from the first coil running to the second? Or does it just not matter? Thanks for the info guys, much appreciated.
That's what I'll be doing. And just to make clear what I was asking, 'wire' refers to only say the positive wire, and then the same would be done for the negative. So I can either run the wire right through, stripping the part where it would run through the first coil contact, or just solder 2 together and run it straight in then back out.
BoNkA
BoNkA
PA
BoNkA
vegang
vegang
