Im conFUSED about FUSES
Qwerty
I am installing an Alpine MRP-M200 and a Zed Audio Gladius, each with a fuse rating of 25A. I have decided to run a 4AWG power wire about 10 feet to the back of my vehicle, at which point it meets a fused distribution block. Two 8AWG wires will then travel to my amps, which are only a few feet away. My question then becomes, which size fuse should I use just after the battery and at the distribution block?
I might add that Zed Audio specifically states that the Gladius, or any other amplifier for that matter, should not be over fused. My logic tells me to use a 50A fuse after the battery and two 25A fuses at the distribution block. Can someone explain?
50 and 2 25s sounds good to me, overfusing to an amp that has no internal fuses can allow the amp to draw current well above what it can handle and possibly start a fire, most amps have fuses built right in so its usually something you don't need to worry about.
so if my amps have internal fuses, it is okay to overfuse w/o risking any damage or starting a fire. However I am not sure if the Zed Audio Gladius has any fuses on it. If so I think I should stick with the 25 amp fuse rating explicitly stated on their website.
if you err, do it on the small side (40, 20/20) rather than on the high. A fuse can pass a lot more current than its rated for if it's only for a short period of time (such as music dynamics). Playing it safe isn't going to hurt anything, and COULD save an amp some where along the line.
Qwerty
Qwerty
Memphis, TN
tRiGgEr
vegang
vegang
