What Exactly is Clamped Power?
  • 6
Real life power after rise and voltage drop.
Taramps Bass 15k wired at 1 ohm rising to 4 ohms.
A clamp meter or Termlab with clamp.
This is the reason I always recommend getting an amp that does double the power that your subwoofers recommend. To combat rise.
I had two of the Xtreme 12's and they were dual 4ohm. They read at like 3.5ohm per voice coil which is common.
Run the biggest AGM you can under the hood, the parallel runs to one of these - should be everything you need and then some...
442
What amplifier(s) are you using? What speakers? Is this your main battery or is it a 2nd battery? If it is a 2nd, how are you wired up? What if...
347
Bobbytwonames
Trigger Man!
Bobbytwonames
Vegas
mastershake575
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
