What else do I need?
Going to upgrade to a CAB ultra 12 and a CAB 1600.1 in my trunk. I had a cheap 4ga wiring kit before. I'll buy:
25 foot run of Royal Excelene 2/0 welding cable. should be enough for power and ground (and maybe part of the big 3)
Sub
Amp
I'll make a custom box
I'll make one run of the 2/0 power cable. This will go to the CAB 1600.1 and then to a small Kenwood amp for my component fronts. Do I use a distrubution block, or what to split the power cable to each amp?
I will have a fuse next to the battery, do I need fuses next to each amp? What size fuse next to the battery? Next to the amps?
Is there such a thing as a quick release connection for the sub box? In case I get a flat, I'll have to take out the box to get to the spare...
I will have this sub and infiniti component fronts. That's it. Is there anything like a sound processor/etc I should install while I have things torn apart? My head unit is a Pioneer P3200BT, is the equalizer on that good enough?
What else am I forgetting?
Thanks.
u should buy 50 ft and be done with it., cost u more buying smaller piece later, just get 2ga or bigger ofc.. u can use fused dist block, and ground block make sure u understand the wires from those are 1/2 size of wire from batt put blocks close to amps as u can within a foot or less maybe, so if u run 2 ga will need 2 short over sized 4ga from blocks, if u use 0 ga from batt use 2 2ga pieces to amps... fuses go by wire size i'll get u link to wire/fuse chart.. so wait to buy fuse holder until u sure on wire size., at amps if using smaller wire as i said u could maybe use 200amp fuse per amp (some peeps fuse buy the amp not wire) sou can use smaller one on kenwood as example, remember if u use fuse to small worse that will happen is fuse will blow which is y it's there but if u use fuse to big as my friend did with cab before he upgraded his wire he melted wire, fuse to big can't hurt amps and car.. just scroll 1" down u see chart http://bdfuses.com/fusesnwires.php
slm9s
slm9s
WA state
BOOMINGRANDPA
