I don't....pm it to me and I'll get at ya later tonight or tomorrow.....doing great man! finishing this install as we speak! you still got my number? we need to catch up
I don't care either way but I don't understand the reason for making this thread?lol but if i said i had a 100% sundown setup you wouldnt be hating... you guys are pathetic...
Umad?lol but if i said i had a 100% sundown setup you wouldnt be hating... you guys are pathetic...
They rate their amps at a lower voltage. When those dozens of amps will be losing efficiency, DD's are just getting into full stride. They are built to a higher standard than just about any company out there including sundown. They are smaller and have more heatsinks which helps with cooling and makes them smaller so you can fit a higher powered amp in a small area...Umad?
Still not impressed. Can you tell me what precisely sets DD amps apart from every other big Korean class D out there besides being grossly under-rated? I read their web page and they try to use a bunch of big words to make people think they're made of leprechaun scrotums and soldered with unicorn tears and are just 10X better than a dozen other amps that are built on the same circuit in the same factory.
3 MINUTES AT FULL TILT?! NO WAY! obviously an awesome daily driver...They rate their amps at a lower voltage. When those dozens of amps will be losing efficiency, DD's are just getting into full stride. They are built to a higher standard than just about any company out there including sundown. They are smaller and have more heatsinks which helps with cooling and makes them smaller so you can fit a higher powered amp in a small area...
Basically it comes down to this.
How many extra batteries do I have? 1
How many ho alts do I have? 1
How many watts am I doing? Around 11k.
Tell me where someone is doing with 1 battery what I'm doing. Especially playing it at full tilt for atleast 3 minutes and not just a bass race....
Since when has anyone had to explain how they could afford their setup??? GTFO!I hate when people act rich online. If you saved up to do your setup right then just say that! If you work hard and like to reward yourself then effin say that!But if you just wanna act like u reached under your bed grabbed a bunch of stacks and just went to the store and bought it all then follow the instructions in Dragnix sig!
OP, nice setup btw.
just gonna run it at 2 ohms.Nice setup. Are you doing another S4 or just going to run that one at 2 ohm?
More heatsinks? Higher standard? Where are you getting this, DD marketing?They rate their amps at a lower voltage. When those dozens of amps will be losing efficiency, DD's are just getting into full stride. They are built to a higher standard than just about any company out there including sundown. They are smaller and have more heatsinks which helps with cooling and makes them smaller so you can fit a higher powered amp in a small area...
he said scrotum //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gifUmad?
