What do you know about a 100% DD setup?
I already know how many relied on t/s to pick their subs, the answer is none.
Yep, SPL guys dont care if the sub they chose has as fs of 60hz, or 18hz, right? SPL guys dont care if their sub has an xmech of 5mm, or 40, right? SPL guys dont care what the BL of a sub is, right?
Ive tried reasoning with you on this point, agreed that (good) SPL guys rely in trial and error to fine tune their system to achieve their goals, but you just wont let the topic die until we somehow come to an agreement that SPL guys dont use t/s in any way, shape, or form. Which is ridiculous. And this all started because I said I dont like how DD withholds their t/s specs. If DD only sold SPL competition equipment, to SPL competitors, and SPL guys never use t/s specs... your stance would be valid. Unfortunately, neither of those is true.
Have a nice day.
DD amps are nicer on 12v systems then others they do more power at lower voltage, especially compared to sundown and cactus.
So a DD m3 will make more power at 12V than a Cactus K9, Audio 20K, AB 1100.1, or are they just under-rated?
MA HK4000 is rated at 50W so it must be a supperior amp then right since it's a `50W amp that does close to 4KW?
I already said they are under-rated, so are others. Really what is actually different about them than the rest of the big class D Korean amps?
Wow, look at all the extra heatsinks. This is a real triumph of engineering here! Go team Korea!
cdimic25
cdimic25
Falcons
