What do you guys think????
P_diaz82
Was considering buying this since my amp is 500 watts stable at 2 ohms.
Pioneer Premier TS-W2501D2
2500W Max, 10" Dual 2 ohms Champion PRO Series Subwoofer
Each Purchase = 1 Brand New Sub!
Click to View Larger Image
360° Product Spin
Description
Features & Specs
Accessories
Store Policies
Item Condition: Brand New
Each Purchase is for 1 Subwoofer.
10" Dual 2 ohms Premier® Champion Series PRO Subwoofer
Power Handling:
Peak: 2500 watts
RMS: 800 watts
Impedance: Dual 2 ohms
Air Suspension System for consistently clear, powerful, wide ranging bass response.
110oz Double-Stack Magnet with Double-Stack Top Plate
Wide-Roll 3-Layer Fiber Radial Surround consists of two layers of urethane with a layer of interwoven fiber between them. It's strong, stable, and it reduces distortion. In addition, the wider-than-normal design provides a long, linear excursion for excellent control and heavy-duty durability.
IMPP Cone with Carbon Fiber/Glass Fiber Reinforcement: Pioneer invented the process of injection-molding polypropylene to form a speaker cone. Now, the IMPP is reinforced with carbon and glass fiber, providing speaker cones with extraordinary strength and rigidity — and light weight. This is ideal for powerful, accurate music. And it gives the cones the durability needed for withstanding heat, humidity, and dust.
Cast Aluminum Basket: one-piece aluminum basket assembly holds the motor assembly, cone, and magnet structure securely in place. The benefits of this design: reduced internal stress, superior damping, and increased magnetic efficiency.
Integrated Single-Sided Silver Compression Wire Terminals
Frequency Response: 18-1000 Hz
Sensitivity: 87 dB
2-year Sonic Electronix warranty
Product Summary
Was considering buying this since my amp is 500 watts stable at 2 ohms.Pioneer Premier TS-W2501D2
360° Product Spin
Description
Features & Specs
Accessories
Store Policies
Power Handling:
Peak: 2500 watts
RMS: 800 watts
Sensitivity: 87 dB
Product Summary
I think maybe i read wrong but if your amp is 2 ohm stable and you got a DVC 2 ohm then your wrong. Sub = 1 ohm load or 4 ohm load...not 2.
Yeah I'm new..... So what's wrong with just wiring one side? What if it was a single coil at 2ohms? I would have no choice but to wire it that way right....
P_diaz82
P_diaz82
Oxnard CA
mclerico83
michigan born
    May 14, 2026
michigan born
    May 14, 2026
