what do you guys think of audiobahn and kenwood amp's?
Audiobahn ABB122N 12" Enclosure
View larger and other pictures
Audiobahn ABB122N
Product ID: abb122n | Product SKU: 4945
Click here to shop for other Audiobahn car audio products.
Product Description:
Dual 12" Ported Bass System
RMS Power Handling: 800 watts
Black Carpeted Covering
Extended Low Frequency Slotted Ports
Audiobahn Embroidery
Dual 10" IMPP Cones with EPDM Rubber Surrounds
45 oz. Strontium Magnet
2" 4-Layer Voice Coil
Bumped Back Plate
Extended and Vented Pole Piece
Gold Binding Post Terminals
Sensitivity: 99 dB
Frequency Response: 22 Hz - 1 kHz
Impedance: 4 Ohm Mono
Dimensions: 29-1/2" L x 17-5/8" W x 14-7/8" H
Kenwood KAC-9152D
Kenwood KAC-9152D
Product ID: kac9152d | Product SKU: 4351
Click here to shop for other Kenwood car audio products.
Class-D Monoblock Amplifier
Bass Boost Level and Frequency Remote Included
Variable Low-Pass Filter: 50 - 200 Hz (24 dB/Oct.)
Variable Input Sensitivity: 200mV - 5V
Phase Shift: 0° / 180°
Variable Infrasonic (Subsonic) Filter: 0/15Hz/25Hz (18 dB/Oct.)
High- and Low-Level Inputs
1 Ohm Stable
RMS Power Handling:
500 watts x 1 chan. @ 4 ohms
900 watts x 1 chan. @ 2 ohms
900 watts x 1 chan. @ 1 ohm
Preamp Outputs: 1 Pair
Bass Boost: 0 - 18 dB @ 40 - 100 Hz (Variable)
Dimensions: 15" L x 11-5/16" W x 2-3/8" H
1-year Sonic Electronix warranty
Amplifier Specifications:
Number of Channels 1 - Mono
RMS Power (4 ohms) 500 watts x 1 chan.
RMS Power (2 ohms) 900 watts x 1 chan.
RMS Power (1 ohm) 900 watts x 1 chan.
Bridged RMS Power Not Bridgeable
Peak Power Output 1800 watts
Min. Impedance Unbridged 1 ohm
Min. Impedance Bridged Not Bridgeable
THD @ Rated RMS Power 0.5%
Speaker Level Inputs Yes
Amp Preamp Outputs Yes - 1 Pair
Built-in Crossover LP (50 - 200Hz), Subsonic (Off/15/25Hz)
High-Pass Crossover N/A
Low-Pass Crossover N/A
Subsonic Filter N/A
Signal-to-Noise Ratio 96 dB
Channel Separation N/A
Bass Boost 0 - 18 dB
Bass/Gain Remote N/A
Fan Cooled No
Fuse Rating 30A x 2
I have an x811d and my friend has a 9152 both of which are not truly one ohm stable, they shut off after about 10 mins in the middle of summer at 1 ohm if you push them hard. Mine did eventually blow a trace @ 1ohm on the output stage of the board but it was fixed for free at a local competition and it has worked great since with no problems. Now I run it at 2 ohms on just one sub. They are still good for the money you can get them pretty cheap on ebay. I seriosuly doubt even though mine is CEA rated 1016 watts @ ohm that it can push that for very long without shutting off. A JL 500/1 was louder than my x811d and didnt even warm up when we swapped it out on two type r 12's. Unless you really like the looks of them or you can get a great deal, I wouldnt buy another one just get a used amp that is known for high quality.
i have i went 2 months with a 8151d. and it did the job on my type r's but u need todo something else for bass. it will sound ok but its not really 1ohm stable and if u dont set the gains right it will be clipping excessively.
I read good reviews of the xxv-03a, which was kenwood's 25th anniversary class d amp. It was rated 1000w rms @ 1 ohm. I think they stepped up the beefyness of the amp to make it actually 1ohm stable.
See if you can still find one on ebay. I think they were blowing them out at like $250 toward the end of their run.
I was gonna get one and run a 15" kicker l7 in my audi, but decided on sql rather than spl and went with two type-x's, so it ended up being cheaper to run a 2000w hifonics amp than two of the kenwoods.
This last bit will hold true for any amp regardless of brand...
I know kendwood class a/b amps are pretty decent. I have no experience with the class d amps, tho. Sounds like it could be a whole different story.
I run a Class D Kenwood eXcelon amp on my 12" (that I bought used) and after 3 years of banging on it daily it still works fine and has presented me with no issues whatsoever at ths point.
I have not used any of the units they advertise to be 1 Ohm stable...my monoblock is run @ 2 Ohms all day everyday and doesn't complain a bit, though. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I have zero experience with anything Audiobahn. Never owned a single piece of their gear.
bang hard
bang hard
chi town
Red Rocket
