What do I use to seal off my trunk?
PrinceCharming
PrinceCharming
I want to seal off my trunk because it leaks on occasion, which i think I have fixed, and because I hear it will improve my bass response as well as reduce road noise. I'm not looking for sound deadening advice because I'm going to do that this summer and I know what to do about that.
My question is, what can I use to seal off my trunk (no air in or out unless I open it up)? I realize I won't be able to seal it completely unless I weld the trunk shut but I want to get it as well sealed as possible while still being able to open it. I've heard of using Great Stuff but I was thinking of using a rubber sealant spray like Flex Seal instead but I'm thinking thats gonna be pretty expensive so whichever you guys think is better.
I do not want to seal my car off from the rest of the cabin, just the outside.
I want to seal off my trunk because it leaks on occasion, which i think I have fixed, and because I hear it will improve my bass response as well as reduce road noise. I'm not looking for sound deadening advice because I'm going to do that this summer and I know what to do about that. My question is, what can I use to seal off my trunk (no air in or out unless I open it up)? I realize I won't be able to seal it completely unless I weld the trunk shut but I want to get it as well sealed as possible while still being able to open it. I've heard of using Great Stuff but I was thinking of using a rubber sealant spray like Flex Seal instead but I'm thinking thats gonna be pretty expensive so whichever you guys think is better.
Id try some Silicone/caulking
But yeah if your trunk leaks silicone the crap out of it. It worked for me. I used to open my trunk and have 3 or 4 inches of water sitting in the spare tire well. 2 tubes of silicone later it's completely dry no matter what.
What I mean is that I want to seal my trunk off from the outside, not from the cabin. I dont want any air coming into it from the outside of the car.
Like if I was going to use my trunk as an IB
Is there like a spray silicone I can get? I want to make sure I cover completely where I need to. What kind of caulking holds up to Mississippi summer heat?
No one can be specific on that answer really..That would be up to you to research for yourself/read the Labels for Applications, to determine which best suites you.
He just wanna seal up the trunk opening so that when the trunk is closed no air escapes. That's what I read from that
Correct. I'm trying to seal every boot and anywhere else air can escape/get in my trunk. All I'm asking is what to use. I do not want to seal my trunk off from the rest of the cabin, just the outside.
I still want to be able to open my trunk tho.
116
Any indication that a loose wire may be the issue? I'd start by checking all the +/- connections to see if one has come lose or is starting to...
yall. I unplugged the radio harness and the antenna and plugged it all back in and it works. I guess its fixed… suppose it was the head unit...
817
Thank you all for all the replies, I intend to reply to each and every one individually as I test things out. Here's the latest development that...
13
PrinceCharming
PrinceCharming
PrinceCharming
New Albany, MS
PrinceCharming
    May 16, 2024
    May 16, 2024
