What do i need for 2000rms?
Newer car with a ton of computer stuff? Or is it a vehicle with no computer, mechanical fuel pump, roll-up windows manual door locks, a normal ignition system?
you plan on competing or daily listening? You plan on trying to get all 2000wrms all the time? I wouldn't get that yellowtop, try a powermaster or kinetik battery instead IMO. I got a yellowtop so I know they are good batteries, but for what you're gonna pay you can do better. A bigger alt is a good idea, look into Iraggi alts instead though. They're on ebay and I've heard good things.
this is for daily listening..so no not 2000rms constantly. just for when i feel the need. im a lil disappointed in the box but o well. so i should look at powermaster?
so powermaster in the front, big 3, and 0 gauge run to the back...enough for 2000?
IMO yeah
Im buying two more 2700s for my box to run 2 EQ phd 5ks, so you should be alright, I used my 1 power master 4 gauge to my amps (each amp) 1100D and a 500 watt 4 channel. and only 4 gauge for my big 3, which will soon be all 2/0 welding wire.
im running right around 2kw rms and i needed a bigger alt (150A), but i still get a little dimming even with that and the big 3 done...im considering a bigger battery (possibly a second)
im considering a 250amp alt, big 3, and powermaster batt. how much power (approximately) could i run on that?
I have a 240 amp alt atm, and am picking up 2 more then will be running 2 "3000 watt rms @ 2 ohm amps Ill be running them at 2 ohm daily and burping .5 ohm, I figure I should be fine but may have to get a 4th batt, time will tell //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
http://www.autopartswarehouse.com/details/QQFordQQExplorerQQBoschQQAlternatorQQ19912001QQW0133-1603585.html
Thats supposed to fit your 99 'sploder. Check see if it looks the same If so http://forums.caraudio.com/forum/showthread.php?t=275122 //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
terra
terra
Yes
terra
