My headlights constantly flicker with the bass when I have the volume over three-quarters of the way up. I have and 08 Jeep Wrangler daily driver and a sound quality setup.
My electrical system consist of a JS alternator rated at 300 amps although it only load tests 250, Big 3 kit, and xs power d 3400 agm under the hood. I'm running a kicker class d 1800 watt monoblock at a 1 ohm load and a focal class ab 280 watt 4 channel at a 4 ohm load.
So do you think I should add a superBank or an AGM?
Or maybe even both? I'm getting conflicting answers from everyone.
If the super bank or AGM or both are your recommended solution, how do I wire it and do I need fuses on both?
I have a drawing I will include that shows how I was planning to wire in a super bank. If i need both I will place the AGM right beside the super Bank and run a separate strand of 1/0 to a smd distribution block.
