Fosgate Forever
USSD
What crossover setting should i set my amp at to get the lowest possible bass note.
For the absolute lowest notes the sub is capable of playing, a ported box won't do it. Sorry. Look at the response plots of the same sub in a ported and sealed box. From about 30-50hz the ported box will be louder, but below about 25Hz the sealed box will be louder more accurate and actually in control of itself. Get much below tuning freq, and a ported sub is no longer damped by the enclosure and is actually prone to overexcursion because of box pressure. At the same time output drops dramatically due to port cancellation. In a basic sealed box in a car with cabin gain factored in, most any sub can play well into the inaudible range. I've seen plots of flat response down to 10Hz.if you want lower, you may need to make a ported box.
exactly, but without knowing 100% how his box is, rather small or too large, if mostly want more output, a low tuned vented enclsoure usually get's them what they want, with less power, over sealed.For the absolute lowest notes the sub is capable of playing, a ported box won't do it. Sorry. Look at the response plots of the same sub in a ported and sealed box. From about 30-50hz the ported box will be louder, but below about 25Hz the sealed box will be louder more accurate and actually in control of itself. Get much below tuning freq, and a ported sub is no longer damped by the enclosure and is actually prone to overexcursion because of box pressure. At the same time output drops dramatically due to port cancellation. In a basic sealed box in a car with cabin gain factored in, most any sub can play well into the inaudible range. I've seen plots of flat response down to 10Hz.
