What Crossover points for comps & sub?
sarge_in
Hi,
What crossover points do you suggest for the following in a Honda Odyssey:
1. Focal 165KR : 60Hz - 20KHz
2. IDQ10 D2 V3: 5 - 110Hz
Am running both of them through the Arc Audio KS300.4 amp that puts out:
RMS @ 4 ohms 4 x 90 watts
RMS @ 2 ohms 4 x 175 watts
RMS @ 4 ohms bridged 2 x 350 watts
I have my gains set at about mid-way.
The installer initially set the Focals at 110 (I don't have the sub yet). The sound was quite clear but not as warm. I changed to about 80, which made it better for warmth, but i am kinda missing the clarity that I had at 110. So just curious what do others here usually set their crossovers at?
there is no set point
mine are set @ 70hz, other people use 100 and 120hz, just a matter of opinion, 110 is just too high for me, just make sure if you do it low that the speakers can handle it
usually 80hz is a good starting point and go up and down from there if you want to change it
thanks for the responses...i agree none of this is a hard rec...depends on tastes, car setup etc. Wud love to hear from more!
Also, do you setup the HU crossovers (if it has it) same as the amp? Or let the amp be almost full range so you can control just from the HU?
Use one or the other, both together would work but they might affect each other & be unpredictable. The hu is probably the most accurate & it's right at your fingertips.
Remember overlapping & gaps are perfectly acceptable. In an open cabin like an SUV you might want to lp the sub kinda low & have a gap to keep the bass up front, then use a shallower slope to blend. In a trunk car you might want to lp higher to help the top end fight its way into the cabin, having an overlap of frequencies might blend better in this case. Nothing is set in stone, trial & error is probably the best way to go about it.
sarge_in
sarge_in
Orange County, CA
probmxstyle
vegang
vegang
