ground it finecheck the ground.
wheres it located?
did u properly sand away paint?
how long is it?
alright thanksMine started doing the same thing yesterday, We had it on a meter and I took to long with some adjustments and smelled coil. Shut it off let it cool down and on the way home it started doing exactly what you are describing.
I'll let you know what it is causing mine later on today after I mess with it a bit.
Bass Boost Was Turned Off Before i even unplugged the bass knobTURN OFF BASS BOOST
not but i will this weekend for sure but i know i wired them 2 ohm b/c i had the laptop right there beside me looking at 12volt.com to tell me how to wire to 2 ohm so i know i got it right but i will check this weekend and try and tune the amphave you checked the way you wire your voice coils
