What could be wrong?
the base knob controls the gain. unplug the knob and set the gain at 0. gradually turn up the gain and see if the problem starts. might have something to do with a hella bad signal.
if the problem starts when the gain is cranked, set the gain where u want below that point. with the knob unplugged turn it to max and then plug it back in
Mine started doing the same thing yesterday, We had it on a meter and I took to long with some adjustments and smelled coil. Shut it off let it cool down and on the way home it started doing exactly what you are describing.
I'll let you know what it is causing mine later on today after I mess with it a bit.
alright thanks
why when i disconnect my bass knob my bass is low but it turned all the way up on my amp and radio?
have you checked the way you wire your voice coils
not but i will this weekend for sure but i know i wired them 2 ohm b/c i had the laptop right there beside me looking at 12volt.com to tell me how to wire to 2 ohm so i know i got it right but i will check this weekend and try and tune the amp
its a signal issue if the subs are making sound.
1) Headunit could be shit (doesnt matter if its new, shit happens)
2) RCA's could be shit
3)could've messed something up internally in the amp (doubt it though)
4) its not the sub, if the sub is playing.
stilltippin863
stilltippin863
Florida
stilltippin863
