mysilver02alty
Looking for some good 2 way components suggestions.
I have this Power Acoustik TS960 amp:
http://cgi.ebay.com/Power-Acoustik-TS960-4-4-Channel-960W-Plasma-Amp-NEW-06_W0QQitemZ250083260235QQihZ015QQcategoryZ4950QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Specs say:
100 watts RMS x 4 at 4 ohms (125 watts RMS x 4 at 2 ohms)
250 watts RMS x 2 in bridged mode (4-ohm stable in bridged mode)
Variable high-pass/low-pass crossover (40-250 Hz, 18 dB/octave)
Variable bass boost (0-18 dB)
Speaker- and preamp-level inputs
Tri-way capable (Tri-Way Crossover required)
Preamp outputs
Fuse rating: 2 x 25A
Requires 8-gauge power and ground leads with a 60-amp fuse ý wiring and hardware not included with amplifier
I'll be bridging it to get to 250 x 2 @ 4 ohms.
What do you think the actual power output of this amp would be, bridged X 2 @ 4 ohms?
And what speakers would you guys suggest that are able to handle that power.
Ive been thinking about Rainbow SLC265's, Boston Pro60's DLS up6's, & CDT HD-62's
Specs say:
Preamp outputs
