What budget amp for a single 12?
Wow that's cheap. Maybe a little too cheap. Looks too good to be true :/
If you want to spend a little more on the amp $122, this will still power your Sub and if you decide to change sub you will have plenty of power on 2 and 1 ohm
RMS Power Rating:
4 ohms: 475 watts x 1 chan.
2 ohms: 750 watts x 1 chan.
1 ohms: 1000 watts x 1 chan.
Hifonics HFI1000D 1000W Mono Class D Amplifier : VMInnovations.com
I have seen a review and test of a 4-channel MB Quart Fx amplifier. It did half of its rated power. Skip that IMO. Most of really cheap amplifiers are junk.
I got a NIB Krypt Audio Micro Monoblock for 150.00 shipped. Your sub doesnt need much power its only rated at 150-300rms. The Krypt amp does 250rms+ at 4ohm and 500+ at 2ohm and it is tiny as hell.
//content.invisioncic.com/y282845/emoticons/eyebrow.gif.fe2c18d8720fe8c7eaed347b21ea05a5.gif Oh man. Do not buy a prefab ported box, they need to be designed properly for the sub that will be going in them. There's many guys here that design and build them, look in the enclosure section.
my pvc box did 150's on music?
Cyclops Hifonics VII VIII mono amp will out perform all the amplifiers stated @4,and 2ohms stable with stock vehicle voltage,bar nun.I will make a vedio in about a month from now to show the real true power from an old school amplifier, of true wattage+rms power.Doesnt need 4ga for power supply like all the other amps, and you dont need to beef up your electrical to get rms out of the amplifier as todays need.The more power you give this amp, the more it draws, and pushes.CHEATER Amp,It beat the dog snott out of an old school 12in Stroker @1"oClock!
killeraxemannic
killeraxemannic
Colorado
audiobaun
michigan born
    May 14, 2026
michigan born
    May 14, 2026
