what battery should i buy
so i have a question on one batt my drop would be to low so if i run 2 of those group 24 batts do you think i would be ok? i may be able to back a little room behing my seat for a batt back there unless i can figure out how to make something that i can mount under my toolbox while keeping it off the bed and not f ing anything up
U would more than likwly need a group 34 up front and a group 31 in back its alot bigger ..to even have a chamce..and even then u will not be able to play very log without getting dangerous drops
well im not to sure how i would be able to fir a g34 up front my batt tray isnt very big and i dont really know how to go about like making one or anything i could prolly fit atleast one batt behind my seat have you ever heard of anyone making any kind of suspended rack for batts under a tool box?
Group 34 is the smaller one ..group 31 is larger..oh yea ive seen batt shoved everywhere...most trunk cars batts get shoved in the spare tire space
oh ok im not very familyer with batts and stuff ive never really had a build where i needed one you know since im only 17 my builds have been smaller but im really wanting to go all out on this one so it will stay and not be switching till i buy a bigger truck how many batts would you think i would need in the back after i get one for the front?
2 to be safe but u will still be workin that alt hard..look into a ho alt...and get a stinger digital volt meter and wire to amp to monitor voltage drops
i was planning on getting a volt meter really likeing the smd one but just to much for a volt meter and ive looked into ho alts but its kinda hard to find them for somereason and is there anything wrong with buying lets say a cheaper one thats not like a dc or one that cost like $600 for one i found a i think it was a 250 for right under 300 but i dont remember what brand
I wouldnt buy a cheap alt but there are cheaper quality alts other than dc..i run a mechman 240 ..i think it was around 350..tenney is also apopular cheap choice
---------- Post added at 12:55 PM ---------- Previous post was at 12:55 PM ----------
Stinger volt meters r 22 bucks
whats funny is there 22 bucks from every where but stinger there like 44
i have the 4.3 liter v6
good that means that you can run a ad244 alt. you can get a stock one out of a 04 145amp for like $150 from the parts store
also if you feel up to it you can get one from the junk yard and rebuild it for $120 for a 200amp output.
get a stock one out of a 04 what? s10? im not sure but i think my alt is a 85amp so would 145 amps be ok for charging up to 3to4 batts?
get a volt meter so you know what your voltage looks now and compare how it is after you do the big 3, replaced your battery, added another battery etc... this will determine how much power you are using. I have a 35ah small battery running brz1700.1, RF p1000x4d and usacoustic 2080 and my electrical hold sup pretty good, very few times i dropped at 12.5 but its steady at 13.8 to 14.0, im plannig to get 2 more 35ah, battery depends on how you use your system i dont crank up every time i get in the car and i don't compete
as of Right now i dont have asystem in my truck well just door spreakers a tweets but thats it right now i have my type s's but there not in it right now but i can tell you when i was running a sundown sa 12 on a alpine mpr-500 the voltage gage in my truck would almost hit the 11 mark
big boom crew
big boom crew
valdosta,GA
rfmayhem
