What battery for approximately 2000 watts?
dsturbd
Alright, car is a 97 Honda Civic, not sure about the deminsions on the front battery, but I know it isn't too big, so what could I go with to power a 2000 watt amp?
Maybe a hc800 in the front? and 1800 in the back? What do you suggest?
When I had a single Sundown Audio 1500D...I was running a Yellowtop up front and a Kinetik 2000 in the back..and it worked just fine..
My friend runs a Soundstream PCA 2000D with 1 Yellowtop up front and 1 Yellowtop near the amp and his voltage never drops under 13.4..
A Kinetik 1400 should be plenty IMHO.....
well i am running 2300rms and i have no big 3 done yet but i have a 130amp alt, gold duralast upfront, with a run of 1/0 for pos and neg to the back battery stinger spv70 and only getting drops down to 12.7-13 volts when testing at the back battery at full tilt at idle with lights on
kinetiks site says to put a 1400 in front and a 2000 in the rear, you will never fit a 1400 in the batt area of your honda unless you modify the batt area,
so 800 in front and 1 2400 in the rear, or maybe 2-1400's, depends on what other amps you have???
hc1400 should fit, its a g51 batt like honda civic's have
ive got a d5100r in my honda fit
I stand corrected, I just went out and measured my batt tray and it is
9.5" wide X 9" tall (including batt terminals) X 5" deep the 1400 will just fit, you might have to do a little massaging but nothing major...Sorry for bogus info...
Do yourself and your system a favor. Grab a hc2400 or a deka 9a31(cheap as hell, shipping is cheap too). Both will run 2000-2300 pretty well(ran that and voltage wouldnt go below 13.9)
dsturbd
dsturbd
Tulsa, Ok
Team MAF
Mike Mccabe
