What are better shivas or brahmas
What driver is "better" is typically based upon the application. Yes the brahma is a higher end driver, but if you only have say..300x1@4ohm for amp power, the shiva would be a better route. Or if you dont have $350 to spend on your sub..etc etc. Both are nice drivers though, one is just a bit more....extreme than the other.
Originally posted by ElementalG20 What driver is "better" is typically based upon the application. Yes the brahma is a higher end driver, but if you only have say..300x1@4ohm for amp power, the shiva would be a better route. Or if you dont have $350 to spend on your sub..etc etc. Both are nice drivers though, one is just a bit more....extreme than the other.
He meant to ask which one was more high end...I'm pretty sure.
Bulldg2686
Bulldg2686
Maryland
RangerMan
