Sealed I would throw a couple hundred more at em probably but no big deal if you dont...thanks! whats the max watt/rms you guys would run on these
O ok well then be a little easier on em but Im sure you have read around at what they can do...im going ported, 30hz
Your to late on all of thatGet the D4's if you haven't hear that already... And I run mine around ~1300w on my single SA-10 ported ~33hz. That's a lot though. I'd say you're safer around 2000w for the pair. You're not gonna hear any difference between a couple hundred watts at that level anyways. The Massive N4 amp recommend earlier would be terrific. Or an AQ2200.http://www.caraudio.com/forums/amplifier-classifieds/523744-massive-audio-n4-excellent-condition-6-month-warranty.html
BOOM. Right there. Buy it right now.
thanks man!!! ill look into those amps thanks again!Get the D4's if you haven't hear that already... And I run mine around ~1300w on my single SA-10 ported ~33hz. That's a lot though. I'd say you're safer around 2000w for the pair. You're not gonna hear any difference between a couple hundred watts at that level anyways. The Massive N4 amp recommend earlier would be terrific. Or an AQ2200.http://www.caraudio.com/forums/amplifier-classifieds/523744-massive-audio-n4-excellent-condition-6-month-warranty.html
Hahaha beat your @ss to it all!I wanted to REaffirm the D4, and I don't think anybody linked the N4, so I saved him the hassle. **** IT PAYTON!
yes sir that is mine and no i dont have room inside the cab so ill be doing a cut through with the little space i have (bagged)Is that your truck in your avatar?
Reason I ask, truck looks like a single cab. Are young to have enough room for 2 12's in a ported box?
Its called gain my friendii want to get the aq2200d but im scared i might blow the subs, so maybe the aq1200d?
