What amp for 2 RE AUDIO MX12D1 MX 12" subs?
Crescendo 3KWP
Sundown SAZ-3000D
Sundown SAZ-3500D
Just fine something that'll do 3,000+ watts rms @ 1 ohm.
Hope you have the proper electrical to run this much power.
stock headunit should make those subs flex beyond their capabilities //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
I have found that 2 Hifonics 1700.1D Class Mono Amps with 2 Kinetik HC1800 Power Cell Batteries and a 200A alternator work great.. Won the 2005 and 2006 Slam & Jam SPL Comp with that setup.. HIFONICS has NEVER let me down.. Clean, High, True Power. The RE MX12D1 is a very high powered sub that you would think isn't. 1500 RMS is high wattage being that the sub is at 3000W.. It would be wise to use two amps if you are using two of these subwoofers..
I had two Skar amps (4ch & a monoblock) go bad within a year. Post #2 is an excellent recommendation.
968
If the amp is already part of the unit, with the amp built in, you would need a power supply, something like this: Or sell that amp amp and...
The 750 will give you better control at higher volumes as you won't be reaching clipping as soon..
He wants to strap the amps to double the output to one sub. Some amps allow you to "couple" them. This allows you to wire up the one sub powered...
jacobcrny
jacobcrny
Chattanooga, TN
CarFanatic
slater
    May 2, 2024
slater
    May 2, 2024
