what amp do i use with these subs?
megadean69
I'm new to all of this and I was wanting to know what amp to use with Dual BP1204 12-Inch 1100-Watt Illumination Bandpass Subwoofer
•Watts RMS: 600 watts
•Watts Peak: 1,100 watts
•Sensitivity: 89 dB
•Frequency Response: 25 to 200 Hz
•Impedance: 4 ohms
•Height: 14.2 inches
•Width: 29.5 inches
•Depth: 14.2 inches
here's what they are. http://www.amazon.com/gp/aw/d/B000UTMDOC?d=d&pd=1&qid=1417922766&sr=8-2-spell
This is all I know about the subs
I'm new to all of this and I was wanting to know what amp to use with Dual BP1204 12-Inch 1100-Watt Illumination Bandpass Subwoofer •Watts RMS: 600 watts
•Sensitivity: 89 dB
•Impedance: 4 ohms
•Width: 29.5 inches
•Depth: 14.2 inches
any mono amp with 400 to 600rms @ 4ohms.
i say that because im sure that sub will not take 600rms .
just remember if the amp say it will do 600rms your sub will not be getting 600rms . not with music anyway.
sure that fine. you can only do what you can do.. i get it...
if you can, get a good amp that way down the road when you get a better sub you will have a good amp.
but just to let you know you could have done way better for about the price of that.
if you can sent it back you would be better off, just saying. if not use it until you blow it.
---------- Post added at 05:47 PM ---------- Previous post was at 05:46 PM ----------
this is a good amp..
Q1-750 Amplifier
or
http://www.sonicelectronix.com/item_77171_Precision-Power-PPI-BA2600.1D.html
mono is the abbreviation for monoblock.
Single channel, mono, monoblock, sub bass amp, Low Freq amp, amps with LPF only for x-over.
megadean69
megadean69
Dayton Ohio
megadean69
